TractorLinks.com
Show Parts for Model:
Re: installing sb chevy in H
Buzzman72
07-08-2014 18:46:10
Saw an H with a Chevy 2.8 V6 in it. What made it work was the fact that the owner had pulled the belly pump out, and in the front of the tractor transmission had installed a 4-speed from an early S-10 with a bolt holding the shift rail in second gear...which happened to be right at a 2:1 gear ratio.
So the torque of the engine at the flywheel was doubled, and the ground speed more closely matched ground speed of the original H, as far as up through 3000-3400 rpm was concerned.
Might look into that...if you can find the right diameter clutch disc and spline count to make that work.
