TractorLinks.com
Show Parts for Model:
Re: M - removing starting hand crank
rustyfarmall
07-08-2014 14:27:39
I installed the charlynn pulley on my M just a couple of months ago. I had to remove the 8 bolts that hold the bolster assembly to the frame rails, and using a couple of pry bars, move the bolster ahead about 3 inches. The charlynn pulley will not fit in there without doing that.
IAtractorKid
07-08-2014 17:47:46
 Re: M - removing starting hand crank in reply to rustyfarmall, 07-08-2014 14:27:39
I beg to differ. I just installed the crank pulley for a charlynn system on an M less than a month ago and it will slip in without moving the front bolster at all. In his case I think he will need to move it forward a few inches to get that double pulley off. Rust depending it shouldn"t be too bad of a job.
rustyfarmall
07-09-2014 06:21:50
 Re: M - removing starting hand crank in reply to IAtractorKid, 07-08-2014 17:47:46
Yours may have fit. Mine DID NOT.
S2710
07-10-2014 08:03:06
 Re: M - removing starting hand crank in reply to rustyfarmall, 07-09-2014 06:21:50
[quote="rustyfarmall"](quoted from post at 14:21:50 07/09/14) [quote="IAtractorKid"](quoted from post at 17:47:46 07/08/14) I beg to differ. I just installed the crank pulley
[img]http://photos.yesterdaystractors.com/gallery/uptest/a162515.jpg[/img][/quote]
Yours may have fit. Mine DID NOT.[/quote]
Rusty what did you do to get your fan to clear the pulley on the power steering pump? Also how did you reinstall the water pump drive? Thank You.
Bob
rustyfarmall
07-10-2014 14:24:57
 Re: M - removing starting hand crank in reply to S2710, 07-10-2014 08:03:06
I did not install the Charlynn power steering pump. Instead, I installed a Vickers, vane style pump. I built my own mounting brackets. The belt to fan clearance was a little close. 2 of the blades had sifficient clearance, 2 did not. Go figure. I chose the easy way out, and figured that if 2 of the blades cleared, then the fan must be bent already, so I "adjusted" a little more clearance into the remaining 2 blades. I think there is supposed to be a spacer that fits between the water pump hub and the fan, but I did not have one, nor did I know where to find it.
