Gentlemen,
I have a '42 H that I use as a working tractor. I was bush hogging today and it stated to run rough and finally quit. I knew it was a fuel related problem, so I removed the fuel bowl assembly and cleaned out a lot of rust and scale, reinstalled the assembly and went right back to work. The same thing happened again about 15 minutes later. I removed the tank and cleaned it out a few months back and had no problems. Is there something to clean the rust away or what? I appreciate any ideas.
Regards, Sapper
Regards, Sapper
