Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
installing sb chevy in H
Marti in Mo
07-08-2014 10:50:08
216.74.222.68
I have this urge to put a small block in an h I have and make a parade tractor or tractor ride tractor out of it. question is there a kit or plans to do this, im curious and thought I would ask on here if anyone knows please post. Thanks for any help Marti
[Reply]   [No Email]
504
07-09-2014 21:06:17
199.127.54.155
 Re: installing sb chevy in H in reply to Marti in Mo, 07-08-2014 10:50:08
If you were ever to work it I would want the cam changed to something with a lot of low end, all in by 3000rpm. Any cam company will help you out by phone.(look in any hot hod magazine for a phone #)
[Reply]  [No Email]
ss55
07-10-2014 10:36:06
50.81.112.224
 Re: installing sb chevy in H in reply to 504, 07-09-2014 21:06:17
I think some Massey-Ferguson combines could have GM small block engines (750 -860 maybe 410 & 510?). Would a combine engine have a variable speed governor and a low-speed, high torque cam that would work well in a tractor? Would a motor home engine/cam be a better choice?
[Reply]  [No Email]
rustyfarmall
07-10-2014 14:27:18
208.126.186.41
 Re: installing sb chevy in H in reply to ss55, 07-10-2014 10:36:06
The Massey 410 combines that I knew of, several in our area, all had GM 292 in-line 6 engines.
[Reply]  [No Email]
Mr. Farmall A
07-11-2014 17:55:10
68.32.185.8
 Re: installing sb chevy in H in reply to rustyfarmall, 07-10-2014 14:27:18
I would think a stroker SBC like a 383 might work better in a tractor than a regular 350. Be sure to install a low end torque cam.
This post was edited by Mr. Farmall A at 17:55:25 07/11/14.
[Reply]  [No Email]
GeneMO
07-09-2014 17:19:27
71.51.202.146
Might as well try for a Rolls Royce Merlin. That would be cool.
Geen
[Reply]  [No Email]
dej(Jed)
07-09-2014 11:40:35
141.189.113.1
Here is my F20. It has both the Chevy and Farmall tranys. 327 has plenty of power for whatever you want to do. It is all about gear selection.
[Reply]  [No Email]
ryanwheelock
07-09-2014 08:52:42
67.59.45.224
There is no "kit" for that like rusty said.
[Reply]  [No Email]
David R Inman
07-09-2014 04:21:39
172.56.3.238
Not a H, but our work in progress Super M (M grill) with an IHC V8.
What we are doing is bolt a spacer between the V8 flywheel and the M, so that we can use the M starter. Similar may work with a smaller motor and an H. Good to know a freindly machenist if your going to do such.
[Reply]  [No Email]
ryanwheelock
07-09-2014 08:48:01
67.59.45.224
 Re: installing sb chevy in H in reply to David R Inman, 07-09-2014 04:21:39
Looks tough with the 2 stacks going up!!! Like that you used an IH motor too.
[Reply]  [No Email]
Redturbo
07-08-2014 22:50:58
66.112.187.143
Not a H, its some sort of V-12 gmc gas engine. Saw it @ RPRU.
[img][/img]
[img][/img]
[Reply]  [No Email]
Buzzman72
07-09-2014 01:28:07
74.138.169.48
 Re: installing sb chevy in H in reply to Redturbo, 07-08-2014 22:50:58
Back in the '60's, GMC got the idea to combine TWO 351 cubic inch V6's into a single block...this is the result.
[Reply]  [No Email]
Centex Farmall
07-08-2014 20:36:13
72.105.161.19
An old GMC V6 would look cool and haven't seen one of those done. That was 60 degree motor and had a deep skirt block.
[Reply]  [No Email]
David G
07-08-2014 22:11:56
24.21.120.173
 Re: installing sb chevy in H in reply to Centex Farmall, 07-08-2014 20:36:13
I agree, the GMC V6 is the perfect engine, just gotta find one.
[Reply]  [No Email]
D Slater
07-08-2014 18:14:21
184.14.196.209
This one was feathered in farm show mag.
[Reply]  [No Email]
DeltaRed
07-08-2014 18:02:06
65.100.145.84
I'm with Allen. "Eye candy".It wont have any 'power' unless you wind 'er up tight.Dont know about a "kit",but there are 1000s of cases where someone has repowered an H or M(or any other tractor make/model).But it will look cool with twin stacks.......I recently(last winter) put a 2.8L Ford V6 in an F12.Looks cool,but wont pull the sled as far as an 'original' F12.Might have something to dpo with the 14.9x26 combine tires....
[Reply]  [No Email]
Buzzman72
07-08-2014 18:46:10
74.138.170.6
 Re: installing sb chevy in H in reply to DeltaRed, 07-08-2014 18:02:06
Saw an H with a Chevy 2.8 V6 in it. What made it work was the fact that the owner had pulled the belly pump out, and in the front of the tractor transmission had installed a 4-speed from an early S-10 with a bolt holding the shift rail in second gear...which happened to be right at a 2:1 gear ratio.
So the torque of the engine at the flywheel was doubled, and the ground speed more closely matched ground speed of the original H, as far as up through 3000-3400 rpm was concerned.
Might look into that...if you can find the right diameter clutch disc and spline count to make that work.
[Reply]  [No Email]
Allan In NE
07-08-2014 17:10:56
199.47.66.59
I put a 350 on an irrigation well once. You'll be soooooo disappointed in it as it will be so darned lame. Promise.
Eye candy and that's all.
Allan
[Reply]  [No Email]
high octane
07-08-2014 16:29:43
166.216.130.80
mite fit, if you used 350 frame rails, or 460 framerails. you may need to use a 4 speed bellhousing and bolt that to the Hs engine plate, extend the driveshaft out, and make it use a chevy clutch spline. i tried it once, H bell just wasnt wide enuff to put the block closer back like they do in the M. oil filter n starter wouldnt fit either, so thats why i mentioned the 460 rails. wider, longer, and bolts right up to H bell. hope this helps.
[Reply]  [No Email]
rustyfarmall
07-08-2014 11:05:12
208.126.186.41
I don't think the frame rails on an H are wide enough to accept a Chevy without doing some serious modifications. Several Ms I know of have a Chevy in them, but I don't think there is a "kit" for them.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
