Does a 504 head fit a Super C
Don L.
I had a question from a fellow. Will a head from a 504 tractor with a C153 , fit the block on a C123 in a C or Super C tractor.
And is a head marked 366206R a LP head. The casting number is so bad , one can't read it. But I got from another marked 504 LP.
thanks
Don L.
You can go to the link below an enter "C-123", "C-135", or "C-153" to look up the head and gasket part numbers.
As far as gaskets...
C-123
#366300R2
C-135
#366300R2
After serial # 100,501...
#383525R3
C-153
#383525R3
FIAT PARTS
The C153 heads use 14 bolts (IIRC), while the C123 head uses only 9 bolts. I don't think the holes match up.
(quoted from post at 03:59:53 07/08/14) I had a question from a fellow. Will a head from a 504 tractor with a C153 , fit the block on a C123 in a C or Super C tractor.
thanks
Don L.
I have a head for a C / Super C tractor if you're interested. Email is [email protected]
