farhand loader
butch49
I have a farmall m with a farmhand loader and it has a problem where it jerks on the up and the down action,, has adequate fluid , if I jamb the control forward fast it wont, or I move the control really slow, but I would rather fix the problem, any ideas
carl
Clancy montana
(quoted from post at 13:26:38 07/07/14) What model Farmhand?
Allan
am not sure it has the bar across the top where thecontrol levers are and it is a round bar with a reserve tank on the left similar to a dual loader
This string has my F-11 on my 400. Is it that type of loader? Understand that the bucket is wrong and from a different vehicle.
http://forums.yesterdaystractors.com/viewtopic.php?t=1140059&highlight=
(quoted from post at 17:21:32 07/07/14)
t looks to be the same loader
carl
Mine did come with the reservoir and a pto pump. I did not install my res and pump and am going with my 400 pump and the first line of the hydraulic lines. How long has this been happening..the jerking motions? Is the PTO working properly? There may be some restriction in the line. Is there a filter inline? I would even consider draining the oil in the reservoir into a bucket and put it back in filtered....just to see if there is anything in there causing blockage. The others on this forum know more than me tho.
Den
(quoted from post at 03:15:31 07/08/14)
Den
