TractorLinks.com
Show Parts for Model:
Does a 504 head fit a Super C
Don L.
07-07-2014 15:59:53
I had a question from a fellow. Will a head from a 504 tractor with a C153 , fit the block on a C123 in a C or Super C tractor. And is a head marked 366206R a LP head. The casting number is so bad , one can't read it. But I got from another marked 504 LP.
thanks Don L.
RTR
07-08-2014 14:34:22
 Re: Does a 504 head fit a Super C in reply to DeltaRed, 07-07-2014 15:59:53
I have a head for a C / Super C tractor if you're interested. Email is ihfarmallrtr@gmail.com
mkirsch
07-08-2014 05:02:55
 Re: Does a 504 head fit a Super C in reply to Don L., 07-07-2014 15:59:53
The C153 heads use 14 bolts (IIRC), while the C123 head uses only 9 bolts. I don't think the holes match up.
Bob
07-07-2014 18:53:45
You can go to the link below an enter "C-123", "C-135", or "C-153" to look up the head and gasket part numbers.
As far as gaskets...
C-123
#366300R2
C-135
#366300R2
After serial # 100,501...
#383525R3
C-153
#383525R3
teddy52food
07-07-2014 16:27:51
Are the head gaskets the same? I don't think so!
Gary Mitchell
07-07-2014 20:05:45
 Re: Does a 504 head fit a Super C in reply to teddy52food, 07-07-2014 16:27:51
Aren"t the front of the heads different? I"m thinking the smaller engines have a water port on the front?
