Disk blades
I have a 8ft ih 37 disc I want to put new blades on the rear
gangs. Are the blades 1 1/8? Or bigger. I seen that for the
early model disc the biggest size blades were 18 inches.
Happy 4th everyone!
Take the thing apart and MEASURE the center hole and axle to be sure.Then order your parts.18" blades were probably stock.Again,MEASURE the diameter of both front and rear disk blades to get a 'feel'.Them measure from the center of the gang bolt out to the frame.Then you will know just how big a blade you can install.
