International 444 gas hydraulic fluid in engine crankcase
busterboy
New User
I was cutting grass yesterday and suddenly lost steering and hydraulic lift, engine also started smoking heavily. checked hydraulic fluid reservoir and fluid was extremely low, however I also checked engine dipstick, and it was 3" over the full mark. Can this be the seal on the hydraulic pump? (or something else?)
That's the first place I would look. The seal has probably worn a groove causing the hydraulic
oil to end up in the engine. Hal
Yeah the lift has been pretty weak for a good while maybe time for a new pump I'll check that first Thanks So Much!
You may just need a new seal and a speedi-sleeve
to cover the worn area. That will give the new seal a new surface to rub on. Hal
