BELIZE91
New User
Just bought a 3444 IH with a BD154 diesel. I pulled the dipstick and antifreeze flowed out the tube. The tractor was sitting for 5 years, and ran when parked. I am trying to determine what is broken so I unbolted the first fuel injector and I can not pull it from the head. I want to add water to the radator and see if water blows out. Is there a tool for pulling them ? It is a 2 ear type held with studs and nuts
Hi, there is a little wiggle room in the slots for the bolts in the ears, tap with a brass rod one way and then the other, spray your favourite penetrating oil around the base and then with 2 small nail puller type pry bars pry and tap the ears. Could really be stuck after 40 years.
JimB
