farmall4856
On my 140 the hydrolic pump started to leak by one of the
bolts that mount it to the frame. So took it off found that the
hole inside has hair line cracks in it. Bought a used pump from
a Super c. I was told it was working when on the tractor. So to
make this long story short I put the new one on and started it
up nothing would work. You could push up and down on levers
and nothing would move or make a noticeable sound of
hydrolic fluid flowing. So turned it off and feelt that the pump
was extermly HOT! Is this pump shot to?
