belt pulley seal for A
dmiller
Anyone know a part number for Napa, Oreilly etc. for a belt pulley seal on a Farmall A?
Seal has seeped for years and finally went today while raking hay. Don't really need the belt, but it shares a reservoir with the PTO wich I do use when raking.
CASE/IH website appears to list a part number 71700C1 and then says it is obsolete. I imagine it is just a standard seal of a given size.
napa number is nos 13602. You might have room two put two seals in because the old seal is probly thicker than the new ones.
there is a sleeve between the shaft and the seal, I put some silicone on the inside of the sleeve after it is cleaned to prevent oil from leaking there ,stumper
