Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
gas cap
Ellis Kinney
06-22-2014 15:00:00
74.139.97.108
See previous question about gas cap. The two holes in the top of the gas cap were plugged. I drilled them out with a tiny drill bit. I put the grader blade on and worked for a while far away from the barn and she ran great. OK, here's the question, if there is pressure in the gas tank why doesn't the gas get pushed to the carburetor? Is it something like putting your finger on the end of a straw in a glass and the water doesn't run out? I know this probably sounds dumb, I went to college but I didn't major in fiziks or hydraulics. Thanks, Ellis
[Reply]   [No Email]
Ron in Can
06-25-2014 06:51:59
208.114.152.153
 Re: gas cap in reply to Ellis Kinney, 06-22-2014 15:00:00
Yes IH will send you warranty gas caps I just got 2 a couple of weeks ago they are taller then the originals I forget the web site address but it was mentioned on this site about 2 months ago you might find it in the arcives
[Reply]  [No Email]
Ellis Kinney
06-22-2014 17:11:49
74.139.97.108
Years ago I got three free gas caps for my M's. All of your responses make sense. I guess I had better check the other two. I sure hope this solves my quitting in the field problem for good. Thanks again, Ellis
[Reply]  [No Email]
pete 23
06-22-2014 16:23:22
74.33.68.123
You only build pressure from expansion of the gasses in tank. Not likely to build pressure when engine is running because you would be taking more fuel from tank than the expansion process. Now, sitting in the sun, not running is a whole different ball game. Some gasoline engines with the tank half way over the engine will actually build pressure in tank while running. When I was at Hickory Hills many years ago, they were running a 656 gasoline on a dynamometer and they ran a pipe out of the top of the gas cap outside to vent the fumes but that was mainly due to the expansion from heat that occurred immediately after shut down as tank was pretty warm (HOT).
[Reply]  [No Email]
Mark-IA
06-22-2014 16:19:33
207.177.117.7
I think IH will still give you a free gas cap that eliminates that problem..
[Reply]  [No Email]
pete_5959
06-22-2014 15:07:35
138.162.128.52
No pressure but a vaccum. Gas flows on gravity from tank. Holes plugged caused no pressure in tank slowing down fuel flow to carb...fill a straw and nothing comes out unless you allow air in on both sides..
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
