m sputters at mid and full throttle
Anonymous-0
has new points,condensor,coil,plugs, and carb screws adjusted. idles fine but at mid to full throttle it seems to be cutting out with no smoke. screen in carb is clean, having trouble determning if it is fuel or ignition. any suggestions helpfull.
tried pulling the choke but didnt notice a difference untill full choke and it died instantly, also can't remember what thottle position was when i did the choke. the tractor ran for an hour or so raking hay after points and plugs were changed,coil changed after it ran rough and no change.
points to close, or bad plugs. could also be a bad plug wire. I would pull plugs and clean and re adjust. minor problem , not major.
I wouldn't rule out a faulty condensor even though it is new. I keep all of the older ones I take out any more just in case the new one is junk.
