Pulling with an F-30
Mark Poss
First time pulling a sled with my F-30. Should I pull in 1st gear? How much air in tires? Any advice is appreciated. Thanks, Mark
1st is the normal gear for(antique/farm stock) tractor pulling.If you ever get to go to a 'play' day/fun pull/'test and tune' where you can pull multiple times all day,try different things/gears.... and see what happens.Experiment...
Run 1 psi of air per every 1000 lbs of the weight class. You want as much tire surface on the track as you can get. My
F30 is a little different I pull 1st in both transmissions.
