If you're talking about the linkages on the outside, look up YouTube user "Dan Gingell." He has a video on setting up the clutch and TA linkages:
https://www.youtube.com/watch?v=gnx32ZPE6Og
You'll want an owner's manual for the 560 just in case the measurements are different. I think his video shows the process on a 300 or 350, but the process is the same on a 560.
1. Adjust the TA linkage for 3/16 free play in the clevis slot.
2. Adjust the main clutch for 7/8 at the platform.
3. Install the spring.
4. Adjust the connecting link as short as possible without moving either clutch shaft.
