Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: H Water pump
wayne in mn
06-06-2014 10:12:09
The springs have to be strong enough to maintain a seal on the shaft to impeller when in use.(they pull the impeller towards the radiator)
Owen Aaland
06-06-2014 16:49:54
 Re: H Water pump in reply to wayne in mn, 06-06-2014 10:12:09
The impeller does not do any sealing like what is common on most pumps. The springs only need to keep the impeller from moving back and rubbing on the engine block. The sealing is done by the shaft packing.
wayne in mn
06-06-2014 10:13:18
Should have said "they PUSH the impeller towards the radiator"
VeryOldJack
06-06-2014 15:15:58
 Re: H Water pump in reply to wayne in mn, 06-06-2014 10:13:18
Thanks to all of you who helped me out with information. This is my first dealings with IH machinery. Past experience has been with John Deere and Massey-Harris and prior to that 23 years flying big round engined airplanes for the Navy. I still run out to look when a round engined spray plane goes over. We got everything re-assembled and put in new antifreeze and it is
sitting overnight so we can check levels tomorrow and start it. My grandson started the engine when it was dry. He didn't know it was without coolant but I'm worried about the head. It was just a short run but none would have been much better. Thanks agin to all of you. VOJ
kevinj54
06-06-2014 17:05:23
 Re: H Water pump in reply to VeryOldJack, 06-06-2014 15:15:58
When a machine is down for service it should be disabled.
In this case the battery cable, coil wire, etc since there is no key to remove.
