Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Farmall F-12 Transmission Fluid
FarmallCT
06-06-2014 09:47:48
Hi,
What is the proper transmission oil for a 1937 Farmall F12/F14 and how much does the transmission hold? It has the hydraulic lift on it too. Does anyone know the type of oil and capacity of the reservoir for that? Also, can that same oil be used in the heisler overdrive? Thanks.
FarmallCT
DeltaRed
06-06-2014 15:52:24
 Re: Farmall F-12 Transmission Fluid in reply to FarmallCT, 06-06-2014 09:47:48
TSC(farm stores),Bulk 'plants',Coops,Walmart.......About anywhere that sells oil in 5 gal buckets
FarmallCT
06-06-2014 15:54:07
 Re: Farmall F-12 Transmission Fluid in reply to DeltaRed, 06-06-2014 15:52:24
Okay, thank you for the help.
Dave Allgire
06-06-2014 14:57:50
I've got 3 F-12's and 2 F-14's. I use SAE 85-140 gear lube in all of them. The book says 16 quarts for the transmission. The power lift takes about a gallon. The Heisler overdrive takes about one pint. I use the same lube in the overdrive and hydraulic lift with no problems. HTH.
FarmallCT
06-06-2014 15:20:05
 Re: Farmall F-12 Transmission Fluid in reply to Dave Allgire, 06-06-2014 14:57:50
Okay, thanks for the information. Where do you usually get the oil or what are some good places to find it cheaper? Thanks.
Copyright © 1997-2015 Yesterday's Tractor Co.
