Yesterday's Tractor Co. New Parts for Old Tractors
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
H Water pump
VeryOldJack
06-06-2014 06:52:15
24.220.77.115
I purchased a new water pump for my 1940 H and it arrived with the gland nut loose on the shaft. I'm assuming that I have to add graphite packing to this unit and then tighten the nut. Can someone tell me about this before I make an expensive mistake? The impeller drive studs were not included with the new pump so I priced them at the local Case/IH dealer. Can you believe $57.00 plus change for each one and $6.22 for each spring? Since the old ones were pretty badly worn I intend to make new ones using grade 8 bolts and 75 cent springs I found at my local hardware store. I'm not restoring the tractor, I'm using it for work. Does anyone have a reasonable objection to my stud/spring solution? Please give reasoning. I could use softer studs if necessary. (Grade 5 or less.)
[Reply]   [No Email]
wayne in mn
06-06-2014 10:12:09
66.188.174.211
 Re: H Water pump in reply to VeryOldJack, 06-06-2014 06:52:15
The springs have to be strong enough to maintain a seal on the shaft to impeller when in use.(they pull the impeller towards the radiator)
[Reply]  [No Email]
Owen Aaland
06-06-2014 16:49:54
216.47.33.5
 Re: H Water pump in reply to wayne in mn, 06-06-2014 10:12:09
The impeller does not do any sealing like what is common on most pumps. The springs only need to keep the impeller from moving back and rubbing on the engine block. The sealing is done by the shaft packing.
[Reply]  [No Email]
wayne in mn
06-06-2014 10:13:18
66.188.174.211
Should have said "they PUSH the impeller towards the radiator"
[Reply]  [No Email]
VeryOldJack
06-06-2014 15:15:58
24.220.77.115
 Re: H Water pump in reply to wayne in mn, 06-06-2014 10:13:18
Thanks to all of you who helped me out with information. This is my first dealings with IH machinery. Past experience has been with John Deere and Massey-Harris and prior to that 23 years flying big round engined airplanes for the Navy. I still run out to look when a round engined spray plane goes over. We got everything re-assembled and put in new antifreeze and it is
sitting overnight so we can check levels tomorrow and start it. My grandson started the engine when it was dry. He didn't know it was without coolant but I'm worried about the head. It was just a short run but none would have been much better. Thanks agin to all of you. VOJ
[Reply]  [No Email]
kevinj54
06-06-2014 17:05:23
50.105.85.204
 Re: H Water pump in reply to VeryOldJack, 06-06-2014 15:15:58
When a machine is down for service it should be disabled.
In this case the battery cable, coil wire, etc since there is no key to remove.
[Reply]  [No Email]
Nebraska Kirk
06-06-2014 09:37:37
207.91.4.159
I see no problem with making your own studs out of a bolt, cut the head off and use a jam nut to tighten against the fan. You don't need grade 8, 5 or 2 will work fine. I am with you on the spring solution, why spend $6 on one when you can get them for 75 cents? It is not high tech or an extreme duty spring.
[Reply]  [No Email]
wayne in mn
06-06-2014 08:32:02
66.188.174.211
Ask eastsider about how he rebuilt his waterpump; he is a frequent poster on this site.
[Reply]  [No Email]
Oregon Tractor Jack
06-06-2014 07:55:09
50.137.47.135
I think I bought some of those studs and springs from one of the normal after market parts places. I don't remember who though. They must have been a lot cheaper because I found a bag of like 6 studs and springs in my tool box I didn't know I had....
[Reply]  [No Email]
David G
06-06-2014 07:36:04
205.215.206.18
I bought one from this site that had a loose gland nut also. I would make sure it is packed, tight and have a drop of loctite on it.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
