TractorLinks.com
Order Farmall Cub Parts Online
Re: hydrolic leak on lo boy cub
mkirsch
06-06-2014 04:56:04
For hydraulic oil to be getting in the "torque tube" (that section between the engine and transmission), the hydraulic pump has to be leaking into the engine, and the rear main seal has to be leaking like a sieve.
It's time for some detective work to see what's going on:
How do you know it's hydraulic oil? Are you refilling the touch control constantly?
What seal did you replace? The rear main seal on the engine? Did you use the stock seal in the stock retainer?
The stock seal fits too loose in the stock retainer, and will leak like a sieve. So if you've got a leaky hydraulic pump too, the oil will do an "end around" through the engine and end up in the torque tube.
TEXAN Connection
06-06-2014 12:26:32
 Re: hydrolic leak on lo boy cub in reply to mkirsch, 06-06-2014 04:56:04
was able to get the stock seal to seal on the rear engine seal. (yes I know of the rear engine seal deli-ma) "torgue tube" thats the word Im looking for thank you. Im pretty convinced now its the 2 problems. hyd oil leaking into the crankcase, refilling hyd every 6 hrs or so. (Crank case always over full) and trans fluid leaking into the torque tube. Ordered the new Hyd rebuild kit today, will have to see about the trans seal next.
