Yesterday's Tractor Co. Compare our Prices For Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
adding rear remotes to 300u
corona boy
06-05-2014 19:13:01
174.21.29.38
Hay season is fast approaching and my haying partner just bought a disc mower. That's the good news. Bad news is none of our tractors have rear remote hydraulics to run the pick up cylinder. My 300 has a block and then the valve for three point towards the rear of reservoir. Can I pick up pressure from one of the tapped and plugged ports that are towards the front of the reservoir? If not, what is the way to do this? Can run mower with out remotes but it will make it more difficult.
[Reply]   [No Email]
mkirsch
06-06-2014 05:18:09
65.199.189.6
 Re: adding rear remotes to 300u in reply to corona boy, 06-05-2014 19:13:01
IIRC there should be another place to mount a factory valve in front of the 3pt valve there on the right side of the seat base.
This diagram shows the seat base hydraulic system:
http://partstore.caseih.com/us/LambWebsterNorthJava/parts-search.html#epc::mr59117ar845051
You should have the rear stack of valves for the 3pt/fast hitch, and the front stack should just be a cover.
What you need is a factory valve to install. You just need the valve and some sort of handle. Standard "O-ring" type fittings can be threaded directly into the valves, so you can just run conventional hoses instead of having to find the factory lines.
[Reply]  [No Email]
kub6040
06-05-2014 20:53:14
54.226.109.136
You need a remote the plate comes off the side of hydraulic block a bolt another one on like from farmall 300 or something close .
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
