fire out of exhaust
KarlO
New User
I have a Farmall A that starts and idles really nice. But as soon as I put it under a load it sounds like it's missing, and sometimes it will pop out of the exhaust and fire can be seen coming out of the exhaust as well.
I've been reading that I might be running lean, but there is no adjustment on the TSX157 carb to test that easy. I also have the opportunity to talk with the son-in-law of the original owner who actually worked with this tractor. He says it might be running lean because he's not sure if one needs to run richer with unleaded fuel.
Or it could be running lean because I have a vacuum leak, but I did test that by spraying starter fluid at every joint and listening for a change while it was running... but there was no change.
Or maybe running lean is not the problem at all. Does anyone have any ideas?
That sounds like a great idea. I've done a quick search on how to do that on a C113 engine, but didn't see anything. I'll search deeper, but I don't suppose you have a quick link on the procedure?
Static timing is set with it not running on TDC compression #1 cylinder. The centrifugal advance (distributor only) is much farther advanced, and is controlled by weights and springs in the distributor (under the breaker mounting plate) The rotor should feel springy if turned clockwise (less than 10 degrees) if it does this, and returns to where it was before, it is probably OK. If it does not turn, or turns and stays in either direction, it needs advance system repair (or a rebuilt distributor) Having no advance will make it do the flame trick! Jim
flames are caused by the missing. so missing is the problem. and cause of the missing could be lean fuel. but other causes could also be on the spark side, or valves. valves are un-likely because of normal run at idle.
(quoted from post at 10:47:25 05/22/14) I don't think that is the correct carb number. I'm pretty sure the model A should have a Zeneth carb.
Either a Zenith or a Marvel-Schebler TSX 157 would be correct.
Better check wires to make sure they are in the rite order then check timing its not the gas and its not too lean.
The advance seems to be working fine. Move it forward and it springs back freely. No wobble either.
I'm pretty sure the wires are correct. If number 1 is at the fan end it fires 1,4,3,2... Holy cylinders bat man! It's supposed to be 1.3.4.2!
Sheesh, I've got the carb in the shop and I can't try it until tomorrow. Boy do I feel sheepish. When I changed the plugs I must've put the wires on wrong. The length of the wires fit much better as 1,4,3,2 (I didn't change them). It's been running like this since the beginning of last summer. I can't believe it starts and idles so well.
I had a like problem with a 656 hydro that I overhauled a few years ago. It ran fine until it was under a load on a feed grinder then it would start to miss spit sputter and then die. thirty second later it would start right up and run fine again until you put a load on it. That was the day I learned that D21 plugs were to hot for a engine in good shape under a load. put a set of D15Y plugs in it and its ran fine every since.
(quoted from post at 20:20:14 05/22/14) Does one use a timing light to set the time?
You can, but on the old 4-cylinder engines with their loose distributors, you can find yourself chasing your tail.
Start with static timing, then fine-tune by ear until the tractor runs the best and accelerates the best when you rev it up.
I find the same issue on my EFI tractor with wasted spark if I get miss fires. You are firing on the exhaust stroke for 2&3.
