I have my TA disassembled right know and am deciding what to replace. I know I need new rollers, pins, springs, and plugs. But do I need to replace the "Ramp" that all these parts are in. There was quite a bit of flat-spotting on the rollers and there was pieces of metal around them (Probably due to the flat-spotting). If I do replace the parts mentioned above, including the ramp, is it ok to buy .010" over-sized rollers. This website has exactly what I need but the rollers are over sized.
http://www.link_disallowed/acatalog/UT3571---Torque-Amplifier-Ramp-31669.html#SID=3928
The reason I"m rebuilding this TA is because the tractor would stop and whine when the TA was engaged. So I was told to check out the ramp and rollers. Everything else looks good. So is it safe to assume that the TA will work when I replace the ramp and rollers?
