Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
fire out of exhaust
KarlO
05-22-2014 10:19:18
173.15.95.53
I have a Farmall A that starts and idles really nice. But as soon as I put it under a load it sounds like it's missing, and sometimes it will pop out of the exhaust and fire can be seen coming out of the exhaust as well.
I've been reading that I might be running lean, but there is no adjustment on the TSX157 carb to test that easy. I also have the opportunity to talk with the son-in-law of the original owner who actually worked with this tractor. He says it might be running lean because he's not sure if one needs to run richer with unleaded fuel.
Or it could be running lean because I have a vacuum leak, but I did test that by spraying starter fluid at every joint and listening for a change while it was running... but there was no change.
Or maybe running lean is not the problem at all. Does anyone have any ideas?
[Reply]   [No Email]
David G
05-23-2014 07:29:15
205.215.206.18
 Re: fire out of exhaust in reply to KarlO, 05-22-2014 10:19:18
I find the same issue on my EFI tractor with wasted spark if I get miss fires. You are firing on the exhaust stroke for 2&3.
[Reply]  [No Email]
M.Genrich
05-22-2014 21:43:46
70.197.232.25
I had a like problem with a 656 hydro that I overhauled a few years ago. It ran fine until it was under a load on a feed grinder then it would start to miss spit sputter and then die. thirty second later it would start right up and run fine again until you put a load on it. That was the day I learned that D21 plugs were to hot for a engine in good shape under a load. put a set of D15Y plugs in it and its ran fine every since.
[Reply]  [No Email]
KarlO
05-22-2014 20:20:14
184.195.77.107
 Re: fire out of exhaust in reply to Dan Richardson, 05-22-2014 10:19:18
Does one use a timing light to set the time?
[Reply]  [No Email]
mkirsch
05-23-2014 05:08:28
65.199.189.6
 Re: fire out of exhaust in reply to KarlO, 05-22-2014 20:20:14
You can, but on the old 4-cylinder engines with their loose distributors, you can find yourself chasing your tail.
Start with static timing, then fine-tune by ear until the tractor runs the best and accelerates the best when you rev it up.
[Reply]  [No Email]
KarlO
05-22-2014 20:17:16
184.195.77.107
 Re: fire out of exhaust in reply to Matt Tieken, 05-22-2014 10:19:18
I'm pretty sure the wires are correct. If number 1 is at the fan end it fires 1,4,3,2... Holy cylinders bat man! It's supposed to be 1.3.4.2!
Sheesh, I've got the carb in the shop and I can't try it until tomorrow. Boy do I feel sheepish. When I changed the plugs I must've put the wires on wrong. The length of the wires fit much better as 1,4,3,2 (I didn't change them). It's been running like this since the beginning of last summer. I can't believe it starts and idles so well.
[Reply]  [No Email]
BONO ANTIQUE TRACTOR
05-22-2014 18:59:45
199.68.231.4
POINTS ARE BAD. NEW SET, SET TO 20, PULL PLUGS SET TO 25. SHOULD ELIMAINATE PROBLEM.
[Reply]  [No Email]
gene bender
05-22-2014 17:45:11
67.55.226.121
Better check wires to make sure they are in the rite order then check timing its not the gas and its not too lean.
[Reply]  [No Email]
Lmack
05-22-2014 15:28:26
24.131.50.165
If that is a Carter carburetor get yourself another carburetor.
[Reply]  [No Email]
redforlife
05-22-2014 12:33:02
68.234.121.124
flames are caused by the missing. so missing is the problem. and cause of the missing could be lean fuel. but other causes could also be on the spark side, or valves. valves are un-likely because of normal run at idle.
[Reply]  [No Email]
Janicholson
05-22-2014 12:12:19
199.17.6.78
Static timing is set with it not running on TDC compression #1 cylinder. The centrifugal advance (distributor only) is much farther advanced, and is controlled by weights and springs in the distributor (under the breaker mounting plate) The rotor should feel springy if turned clockwise (less than 10 degrees) if it does this, and returns to where it was before, it is probably OK. If it does not turn, or turns and stays in either direction, it needs advance system repair (or a rebuilt distributor) Having no advance will make it do the flame trick! Jim
[Reply]  [No Email]
KarlO
05-22-2014 19:47:33
184.195.77.107
 Re: fire out of exhaust in reply to Janicholson, 05-22-2014 12:12:19
The advance seems to be working fine. Move it forward and it springs back freely. No wobble either.
[Reply]  [No Email]
Janicholson
05-22-2014 20:02:34
74.60.94.18
 Re: fire out of exhaust in reply to KarlO, 05-22-2014 19:47:33
Good, is it in time?
[Reply]  [No Email]
KarlO
05-22-2014 12:19:53
173.15.95.53
Thanks. I'll check that before I do anything more drastic.
[Reply]  [No Email]
kennytractor
05-22-2014 10:47:25
64.147.45.91
I don't think that is the correct carb number. I'm pretty sure the model A should have a Zeneth carb.
[Reply]  [No Email]
rustyfarmall
05-22-2014 14:39:07
208.126.186.41
 Re: fire out of exhaust in reply to kennytractor, 05-22-2014 10:47:25
Either a Zenith or a Marvel-Schebler TSX 157 would be correct.
[Reply]  [No Email]
KarlO
05-22-2014 11:20:00
173.15.95.53
I'm sure it's the TSX157 because that's what the brass button says that is riveted on it.
[Reply]  [No Email]
Seeing Red
05-22-2014 10:35:31
50.33.214.64
re-set the points and timing
[Reply]  [No Email]
KarlO
05-22-2014 11:24:04
173.15.95.53
 Re: fire out of exhaust in reply to Seeing Red, 05-22-2014 10:35:31
That sounds like a great idea. I've done a quick search on how to do that on a C113 engine, but didn't see anything. I'll search deeper, but I don't suppose you have a quick link on the procedure?
[Reply]  [No Email]
Bob
05-22-2014 11:43:02
64.255.159.192
 Re: fire out of exhaust in reply to KarlO, 05-22-2014 11:24:04
Does it have a magneto or a distributor?
[Reply]  [No Email]
KarlO
05-22-2014 19:45:46
184.195.77.107
 Re: fire out of exhaust in reply to Bob, 05-22-2014 11:43:02
Yes, it's a distributor.
[Reply]  [No Email]
KarlO
05-22-2014 11:46:29
173.15.95.53
I'm pretty sure it is a distributor. I'll check when I get home for sure.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
