TractorLinks.com
Show Parts for Model:
Re: testing a 12 volt coil
teddy52food
05-22-2014 10:00:49
Put a test light on the wire to the dist. Turn it over & it should flash on & off. If it doesn't, the electronic device is bad.
jerry 4
05-22-2014 10:02:52
 Re: testing a 12 volt coil in reply to teddy52food, 05-22-2014 10:00:49
already tested that, but thanks.
Bob
05-22-2014 10:19:48
 Re: testing a 12 volt coil in reply to jerry 4, 05-22-2014 10:02:52
Are we to assume the test light flashed on and off.... or NOT???
jerry 4
05-22-2014 10:31:44
 Re: testing a 12 volt coil in reply to Bob, 05-22-2014 10:19:48
yes the test light flashed when hooked between the+ and - when cranked.
vagasman
05-22-2014 18:37:19
 Re: testing a 12 volt coil in reply to jerry 4, 05-22-2014 10:31:44
I had problems with coil on 300 monday. I conected to ground and had 12v on pos side of coil. Checked neg side with points open and had 12v. Coil bad. Put new coil on checcked neg side with points open and had nothing . Coil good. Cleaned points with emery cloth and tractor started after 4 months parked.
