Super C Pictures
Dan Nees
Here is a picture of my Super C with my C-72 Snow Plow/Grader attached. Also, if anyone is interested I bought LED light bulbs that plug right into the Stock light housings which are 2-24V and are supper bright. From superbrightleds.com part # 67-CW2W They were like $20 a piece or so, but; worth it.
Untitled URL Link
Here we go, figured it out, pictures.
Sorry, I'm a noob here
Yes, 2V- 24V will power these lights. They are very bright and designed for the light to display out the top of the bulb. If you look on the web site they have the lamps in different configurations if your light socket is different.
I like the hook up for the blade. How it connects to the bolster and the torque tube. I am in the midst of designing a front facing blower for my BN USING a brigs twin cylinder 16 HP. to drive the blower
and was trying to think how to attach it to the tractor. the only addition that i will make to your hook up is to run the arms back past the hinge point and use the twin 16 as a counter balance for the weight of the blower.
Nice looking setup you`ve got there. One thing, though. You`re missing the "D" shaped irons that hook into the touch control arms. These irons are where the long arms with the springs that run along the side of the tractor are supposed to be hooked to. I wish I had pics to show what they look like, but I dont. The way you have them attached, I dont think you`ll get the range of movement you should have.
Mark,
I think I know what you are talking about for those
"D" shaped arms. FarmallHal sent me a sketch
drawling of those arms so I can get them fabbed up.
Should give me much more lift on the front of the
blade, which I could use, it is a bit low when
driving.
Here is a photo of the box and label for the light bulbs. Maybe sometime this week, I'll get out in the dark and take a picture lit up for everyone.
