highcropwife
New User
I have an International Industrial M (Yellow) and would like information regarding it. It has been partially restored.
(quoted from post at 21:18:00 05/12/14) I have an International Industrial M (Yellow) and would like information regarding it. It has been partially restored.
(quoted from post at 11:40:45 05/13/14)(quoted from post at 21:18:00 05/12/14) I have an International Industrial M (Yellow) and would like information regarding it. It has been partially restored.
That would be a W-6 or I-6, not an M. I can't tell which though. If it had a pintle hitch, would likely be an I-6 but there appears to be an additional hitch or mount of some sort on the tractor. X1 is the code for gasoline engine. Should be a 1947 model based on the serial number you gave.
The I-6, W-6 and M were based on the same engine. The M looked completely different from the other two, it was a row crop tractor. Looks taller with adjustable rear wheels and usually a narrow front or an adjustable wide front. The I and W versions had the non-adjustable wide front like yours has and where the operator sits was lower on the tractor. Yours has an aftermarket cab on it.
Look at the serial number plate on the left side of the clutch housing where the serial number came from. It should also be stamped I-6 or W-6 I believe. The I-6 or industrial version was usually painted yellow but could be any color also. It appears to have a nice recent coat of paint. Could be a W-6 also, just painted yellow. Nice unit at any rate.
Good for you for getting ready to sell some of your husbands treasures. Sorry for your loss. I hope it goes to someone who will take care of it like your husband did and the tractor lives on to give another person joy of operating it.
(reply to post at 14:10:35 05/13/14)
(quoted from post at 18:48:06 05/13/14) There were industrial Ms built, but that isn't one of them. What I think it may be, is an M that at some point in its life was modified for one reason or another, and over the years, somehow became a 6 series, OR its a 6 series with the wrong tag and hood on it.
(quoted from post at 05:24:01 05/14/14) Im trying to insult you by any means, so please
dont take this the wrong way. Aorund here, that
would do good to bring 600 and that would be
pushing it. Disadvantage here would be that sheet
metal, assuming -6 series, is hard to find, and
would either be expensive, or would have to be
shipped from somewhere. Not knowing its history,
or anything, also makes it less desireable. As for
a working tractor, it has no hydraulics, so that
makes it basically worthless, except as a
collector tractor, and again, without know 100%
for sure why it has the M tag on, what I believe
is a 6 series tractor, will make people hy away
from it.
