HELP
574 fuel shutoff solenoid
doug
12-24-2000 10:44:49
My 574 has a fuel shutoff solenoid in the carb bowl which shuts the fuel off to the main jet to prevent dieseling. Sometimes it shuts off and kills the engine or won't allow the engine to start. How can I get rid of this *&^%$# thing? I can't simply unplug it because it has to have to have power to get gas to the main jet.
Haas
12-25-2000 06:17:17
 Re: HELP - 574 fuel shutoff solenoid in reply to doug, 12-24-2000 10:44:49
I had a 424 that had this. The Solenoid went bad, and I could not get it started. I bought a new solenoid from Case/IH. It was easy to install. Never had any trouble after that.
T_Bone
12-25-2000 01:20:56
Hi Doug,You should be able to unscrew the soleniod and screw in a 3/8NF bolt & nut and set buy running engine at maxmium rpm and adjusting the bolt for non missing condition, then lock the nut. When I bought my 340U it had this set-up and ran just fine. I did however buy the proper needle valve as it looks like someone knew what they were doing instead of the mickey mouse look of the bolt. The exisiting main jet is correct for the solenoid or the needle valve.
T_Bone
Ace Schrunk
12-24-2000 13:00:29
You be able to get the old nut and needle the 460 or 560 used and relpace the solenoid
doug
12-24-2000 13:54:01
 Re: Re: HELP - 574 fuel shutoff solenoid in reply to Ace Schrunk, 12-24-2000 13:00:29
Thanks. I'll give it a try. But, I believe I'll wait for a little warmer weather first - ha, ha.
