400 front wheels
I have the wide front with 3 bolt wheels. Approximately how much should 6 bolt wheels cost? I do have a source near me in Nampa Idaho. Just want to go with a tiny bit of information rather than going in blind. That place also asks for an appt too.
You're also gonna need new hubs to use the other
wheels.I'm not sure the 'new' hubs will fit the old
spindles.Some who knows will hopefully chine in.
Check with yesterdays tractors to see about what the cost is. They sell the aftermarket 6 bolt hubs made to fit a 450 axle. Several other aftermarket company's sell them also. Most in the 125 to 140 range.
Put number 223311 in the parts search box.
Search farmall 560 front rims on line for prices. Used would be cheaper if any in your area.
So I put the farmhand loader with the bucket on yesterday and ran it around a tiny bit. The tires looked like they were half full of air on the bottom halfs on the front. They probably could use some more air I suppose. But the first hydraulic switch/handle that I have the hydraulics set up on has a detent position that can be used to keep pressure on the other switch lines. The loader seems to go up fast enough for me. The only problem I think I am gonna have is the tires. I did see 2 on ebay for 10 per and 30 shipping each. Those were for the 560 as they came of a 560 that was parted out. I also see a 560 diesel that runs but has issues about 200 miles from me for sale. Benton City Wa.
