McCormick No.7
jon5
New User
Greetings. I recently purchased a 10 ft. McCormick No. 7 Fertilizer distributor (drop spreader). I have been unsuccessful in locating an Owners/Operators Manual for the No.7 and any help would be appreciated. Also it appears the tires that are currently on it are not original as they are older 7.60x 15 snow type tires that are dry rotted and in need of replacement. Does anyone know if these originally came with Rib implement tires ?
Binder Books. they will have reprints/copys.Or if you're 'lucky',they will have an original one in stock. Anther place to check is Jensales.
At that time almost nobody would spend the money for new tires for something like that when used car tires would work and they were plentiful. Orignal would have probably been for one of these 3 sizes, 6:70 X 15", 7:10 X 15" or 7:60 X 15" with the first from a Ford or Chevy, last from Like the Oldsmobile or Buick.
And it did not mater if there was any tread on them or not as long as they held air, only thing is both need to be same size.
(quoted from post at 00:11:31 05/08/14) Binder Books. they will have reprints/copys.Or if you're 'lucky',they will have an original one in stock. Anther place to check is Jensales.
Thank you, i will give them a try...
