Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
farmall 200 belt pully take off
dewy
05-07-2014 10:58:13
72.152.233.181
seal leaking on front housing ..ordered new one ..only shows one on messicks diagram,but when i took off housing ,it looks like theres two more. messicks said to take them out and put another outer seal, on inner..also asked if i had spacer or belt pully on because thats what holds it all together.mine does not ..but it looks like some one wegded a piece of metal under spacer that seal rides on..it may be spot weld but looks like metal..also oring ,rubber between bearing an spacer.. cant get spacer off shaft,,maybe thats why its wegded.. seal is still leaking.... any suggestions ,thanks dewy..
[Reply]   [No Email]
Lmack
05-07-2014 14:19:49
24.131.50.165
 Re: farmall 200 belt pully take off in reply to dewy, 05-07-2014 10:58:13
Welcome to the past! There is a slip ring over the Belt Pulley shaft that has no seal nor any interior means of remaining in place . . . unless you mount a belt pulley or a casing. You can get the slip ring from CIH if it is missing. The casing can be fabricated from a section of old chain link fence top rail of the 1" size. Use a plumber"s rolling cutter and cut the rail 2" long. You will need the end bolt and washer to hold it on. The new fence rail sold now is too thin. The oil seal rides over the slip ring and limits the oil that can seep out at this point. There will be metal shims here behind the bearing and seal mounting to fix the clearance of the gears. IH provided no seal for these shims except the close spacing and paint over the outside. It was expected to leak oil and they all do. I did put a bit of form-a-gasket between mine but the space between the slip ring and the shaft has no oil seal. It will leak. You can pack the slip ring and shims in with some heavy weight grease and reduce the leakage but it will not stop.
Otherwise, do not overfill the transmission since none of the seals will hold standing oil. These seals were made to minimize oil loss not stop it.
[Reply]  [No Email]
dewy
05-07-2014 15:04:56
72.152.233.181
 Re: farmall 200 belt pully take off in reply to Lmack, 05-07-2014 14:19:49
thanks lmack ...dewy
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
