TractorLinks.com
Show Parts for Model:
Re: More ph out of farmall H
D Slater
05-07-2014 04:59:04
If sticking with the same block, some options. See if the H block bore is good enough to fit 3-9/16 pistons form a overbore SH or standard bore 300 engine with filler rings in the counter bore. Use the 300, 350 head gasket. Bore the block about 1/16 and put 3-5/8 dia. 350 pistons in. Bore H block about 1/8 bigger and use SH sleeves. Bore H about 3/16 bigger and use 300 and 350 3-5/8 piston and sleeve set. Depending on the block, some may run into trouble with the last two options.
