Hello,
We have a Bush Hog QT Loader on our Farmall 656. This past winter it quit working. You can rev the engine and it will barely raise up with no lifting power at all. I just switched over to using the Allis D17 through the winter. But now I need to work on the Farmall. Any suggestions???
If I remember right from working on them 20+ years ago, they have two pumps, but can"t remember which one feeds the powersteering and 3 point and remotes.
I figure I"ll check pumps and pressure relief valve, but is there anything else I should look for? Thanks in advance.
Scott
Scott
