farmall m shifter
butch49
stuck in neutral, cant shift looks like a pin problem , running great stopped to shift to reverse and nothing could not move shifter into gear.
carl
Clancy montana
Just below the spring and dome shaped plate on the shifter there are two metal plugs. Pull one out with a slide hammer or? to remove the pivot pin by driving it through the other plug. Remove the lever. If the pivot is worn replace it with a piece of grade 8 bolt shank, or buy a sloppy shifter repair kit from Ebay (recommended)
If the rails in the trans are not aligned, push the clutch and move them with a big screw driver or small pry bar till they are aligned in neutral.
The tip of the lever may also be worn. There are images in the archives of the tip with dimensions.
Jim
I always have a hard time finding stuff in archives. But Jim is right. The tip should measure 3/4" fore-and-aft, by about 0.30" thick. I took mine to my good blacksmith, he said he knew all about how to make it, there being so many of those tractors.
Here is a pic I took for a Farmall H. Not sure if the dimensions are the same for an M.
Randy
