Anonymous-0
Posted an earlier message about tips for loosening oil pan drain plug and thanks for the responses. The plug will not come out. After getting under the tractor and getting a good look with a light, the previous owner has the plug so chewed up that there is no choice but grind down the old plug and drill and tap a new one. Two concerns: first...when I drill from the bottom up into the pan is there a problem the metal pieces will work their way and cause an engine problem?? Second: I'm probably going to have to stay with about a 3/8" size hole that is smaller than the original plug...is there a recommend adequate size and thread count that will insure the new plug will not vibrate out??
Thanks Charles
Thanks Charles
