Anonymous-0
Hi everyone. Thought I would try this again. I
posted yesterday and was hoping everyone was busy
with Easter and didn't have time to answer. A
couple three weeks ago I posted a question
concerning the 3-point. We kind thought the
unloading valve was faulty. I took the valve apart
and replaced the o-rings in the valve. I had some
time on Saturday so decided to put her back
together. It still does not work like it should.
It will work when you use the auxiliary valve. It
also works without the aux. valve when you goose
the motor. It will also work by moving draft
control lever up and down with the normal lever
about midway on the selector. I need some
suggestions. Could the valve be sticking? Any
feedback would be appreciated. I know there is a
lot of knowledge out there. Hopefully someone has
seen this problem before. Thanks Doug
