looking for a little advice. I have a farmall A that is proving to be more difficult than I think it needs to. It will start when I have the throttle open all the way and the choke on. It runs like crazy but if I push the choke in or throttle down it dies instantly. I bought the tractor last fall and it ran fine the guy I bought it from had put 350bucks in the carb in 2012 (I saw the receipt). I have had the carb apart half a dozen times and the governor once and the results have not changed a bit. I did put a new manifold on it and I have taken it off and blown through the ports (grasping at straws). I am accepting any and all ideas thanks
