W4 oil pressure
Anonymous-0
the oil pressure indicator needle on the 1944 is just a smige above the red portion of the gauge bar where as on the 1950 it is three quarters of the way up the white bar. both gauges are new. should the oil pressure be that low on the 44?
No it should be in the white or above. What oil is in it? The weight is important 15-40 might help. Also make sure the gauge is accurate. Jim
