Anonymous-0
I recently wrote in concerning the 3 point on my 656. We kind of thought the unloading was faulty. I took the valve apart and replaced the o-rings on the valve. Yesterday I had some time and put her back together. It still does not work like it should. Sometimes it does and sometime it doesn't. It will still work when you use the auxiliary valve. It works like it should when you goose the motor without using aux. valve. It will also work by moving draft control lever with up and down with the normal lever lever about midway on the selector. I need some suggestions. Could the unloading valve be still sticking? Any feedback would be appreciated. Will check back later today. Hope all are having a Happy Easter
