boomer22
wonder if this loader would fit a wide front too? without dismantling the wide front?
I can replace with a bigger bucket is that right?
Is it worth 500 dollars? Bucket needs a bit of work he said.
I have seen this loader at auctions sell for 200 to 500 dollars. Check to see how bad the pins are worn, and check the cylinders for leaks. The bucket looks like it needs a lot of welding.
I think generally the loaders with bent arms like that are designed
to work on a wide front end tractor, the ones that only work on a
narrow front that I have seen are the ones where the arms are
straight from the rear axle to the bucket.
Zach
200 to 500 would be an awesome find.
looking at a spool valve too. different guy, said it was on a loader of a cub cadet 149. Would it work for this application? and is 125 a good price?
I agree. Anything that works is worth $500. As for the rest, sometimes its nicer to start with new. The hoses & fittings look ok, but if they're just a little short, you buy new anyway.
Valves... who knows. Have to ask yourself is it good enough for me?
I have the same IH 2000 loader on my 350 wide front.
It will work just fine but it is easier to take it
on and off with a narrow front. (It still isn't a
quick and easy job, though.) See those extra holes
right behind where the boom cylinders attach to the
frame? Those are for stands that hold the frame up
and you could back right out with the narrow front.
With a wide front you would either have to suspend
the frame from an overhead beam or make stands that
go up and over the front wheels.
According to the photo from a sales brochure the 2000 loader is mounted rather far forward on a 706. The loader in the poster's picture is mounted forward the same as the brochure picture, however it is mounted too low on the tractor side rails. Brochure photo shows loader frame blocking out 706 emblem. Emblem is not blocked in poster's picture. I believe that someone made some type of front mounts for it and they are not of a near factory correct design. Also the bucket is definitely not an IH factory bucket.
