farmall_h_1944
Been having problems with my H after a carb and distributor rebuild. The tractor's idle is the same regardless of throttle position. I've had the carb off and on so many times thinking i didn't get the governor linked up to the carb correctly. I then took manifold off and put carb on governor shaft to see if the butterfly was moving correctly with the throttle. The butterfly would open when moving throttle to WOT but would stick when moving it back to low. I know the shaft is in the tang correctly so I am at a loss. Do you think my governor needs adjusting? I had no problems with the throttle before it died so I am not sure. Any help would be appreciated. Thanks
