Front End Wobble On 560
slifnom
I have checked on the wobble in the archives and was wondering if it could be low oil level! I have replaced the hydraulic pump. If I understand the hydraulic pump also furnishes the powersteering. It will wobble like crazy at times and not so at times. I am thinking I should investigate by taking the frame rail off and the radiator . Or should I first add oil?Anything else to check first? Thanks in advance
I would start by checking for air in the steering . You can just loosen one line turn all the way one way then tighten line loosen other line and turn likewise in the other direction.
