BN oil pump
We have a BN that when it warms up it has good oil pressure until it goes to idle. Then there is very little, less than 5#. I took the oil pump apart and sanded down the pumps cover plate it had grove marks in from the gears. I put it back together with a new gasket and the pump won't turn. If I loosen the 4 bolts ,it will turn but it is still tight. The bolts aren't much more than finger tight. Can I make a thicker gasket to get the clearance ? If so how thick?
Thanks for any help.
Paper thin gaskets are available fot the pump from caseih. Making them from tough resin paper is also possible. The clearance is .001 to .0005" (not much!) Jim
