Loader 706 Front Tires
I got the 2250 loader hooked up on the 706 and have been playing around with it.
I have a mismatched older set of front tires on the tractor. They squat pretty good under any load at all.
I am going to get a wide front in the next couple of weeks. I was just wondering if I should get some bigger tires, or if I should get the standard tires but foam them. Or, don't worry about it.
What would be good tires for the front under this loader? What do you all say?
15 or 16" rims? Either way a 7.5L, 7.60, 9.5L,
10.00, or 11L tire would work nicely, just depends
on how much flotation you want. 8-ply MINIMUM, 12-
ply would be even better.
We bought a used wide front 756 with a loader on it in 1974. Tractor had 9.5L-15 fronts . Inflated them to 50 psi and they were sufficient to carry the loader plus maximum weight that the loader would lift.
