2 Point Plows
Question I just purchased a 3 Bottom large point plow what model would it be and where can you find a parts breakdown for it, I also have 2 plow small point for my Super C it has the large spring on top also what model would it be Thanks for any help.
Messics.com or order a parts book from Binder Books as I did.I own 3 IH 2ways : #39 tumble,#314 and #642 rollovers.Had a #210 but sold it. B..B.. had all the books in stock.
The plow for the Super C is a c20.
Yeah, "I bought a 3-bottom plow. What model is it?" really isn't going to get you much.
IH made dozens of different models of 3-bottom plow, and most of them could be had with Fast Hitch points or 3-point hitch. Or the owner could have modified it, or the dealer could have modified it, or, or...
We need a picture at the very least. Several pictures would be better, because sometimes models look very similar to one another.
Probably a 312 model as that was the most common. We have 2 3 bottom plows and a 412 gold demo 4 bottom plow, Migraine
as stated before IH makes lots of fast hitch plows. This is a 210 2 way plow with a broken standard which I have fixed. i also have a 3 bottom, thanks to Delta Red
if its like the one d slater pictured it would be a 311 as the 312 was semi mounted, your small point one is probably a c20
The small point with the large spring on top is most likely a C-20. If one looks hard enough they can be found in cast moldboard, slat moldboard, and steel moldboard versions. Don't ask me how I know? They may have Super Chief or Plow Chief bottoms. The 3-bottom is likely a 311; they were large point fast hitch. Parts should be available for both with a little looking.
What I pictured is one of the other two and not the 311. Never could tell the other two numbers apart. If it doesn't have a spring and the same type of beam construction as the C-20 it could be one of those. 311 is the top picture. For ID use the bottom of the pictures.
From my couple of years trying to find a model 211 plow for my Farmall 240 I can state that it is not a model 311 which is like the 211 except it being a 3 bottom plow. Both the 211 and 311 have a box beam running diagonally across the back of the plow to tie the beams together which the one shown does not have. My take on the plow, it is a first generation plow made for the early large point fast hitch tractors. Those plow models in my IH application listing of moldboard plows for those tractors are as follows for three bottom one way fast hitch plows of the era are: Models 34-F30, 34-F30A, U-F30 and the No. 30. Someone might be familiar with these noted models which might help with a model confirmation as I have no further information on those models. Hope this helps, Hal.
I`m with Hal`s and Slaters` take on this one. If it looks like a C-20, except with large prongs and 3 bottoms, it pretty much has to be a 34-F30 or later variants 34-F30 & No. 30.
Hal and everyone else that have helped me get this mystery solved it is the 34-F30A with a tail wheel so again thanks everyone and have a great Easter.
