Hello. I bought a cub that came with a plow and disc but i'm pretty sure they aren't cub implements. They seem to hook to the draw bar and lift off the ground by the 2 point hitch and a chain hooked to the back of the disc and plow. The disc is pretty easy to figure out on how to hook it up to the tractor but the plow i can't figure out. The people i bought it from didn't know much about it. It was they're Dad's tractor and remembered they dad plowing with this plow and disc but couldn't remember how it hook to the tractor. They thought that i was suppose to turn the draw bar around backward and the plow bolts to the hitch and the chain hooks to the 2 point hitch. It lifts the plow but the plow won't dig in the ground only slides across the top on the ground. Don't see any place on the plow to adjust the pitch of the plow so the point will dig in. Any body ever used a plow on a cub and hook it to the draw bar and lift it off the ground with a chain and the 2 point hitch?? How do you have to hook the draw bar to the tractor and the plow to the draw bar to make it go in the ground??..Thanks for you time and any help
Scotty
Scotty
