2 cycle gas/oil mix
Gene F.
New User
I am into snowmobiling and have + 5 gallons of gas/oil mixture left over. Would it cause and harm if I used it up in my farmall 340 tractor?
Dump it in......I rutinely put that kind of 'waste' gas in tractors. no averse effects.Those old tractors will run on about anything
best is to use it when you will be working the tractor hard , as it helps prevent plug fowling.
if its a 50/1 mixture not much to worry about as valve guides like lube. and also have at least another 5 gallons plain gas in the tank
