TractorLinks.com
Show Parts for Model:
Re: b414 hydraulics
JimB2
04-13-2014 06:54:01
Hi, does the B414 have a power steering cylinder on the left side of the tractor or does it have two cylinders by the front axle? The British Bradford build B414,434,444,384,B275,276,354,364 and industrial models 3414 and 3444 series tractors, were shipped to Louisville on crates and they were assembled there using different electrical, front axles and power steering systems that were common to USA build tractors.
The British assembled ones that were delivered to Canada had a Lucus electric system and the power steering was supplied by a second hydraulic "Dual" pump that was attached to the rear of the primary pump.
Re your photo, I was trying to determine if the empty hole was threaded or a C-clip grove in the inside? It sure looks like that is where the flow divider valve would be installed. I would search the caeeih.com parts on the models I mentioned above looking for a similar flow divider valve.
Good luck
JimB
hancockian
04-13-2014 07:32:03
 Re: b414 hydraulics in reply to JimB2, 04-13-2014 06:54:01
Hi Jim,
It has single steering cylinder on left. It's a diesel so don't know about electrics. I'm sure all the internals of the divider are missing. there is an O-Ring groove inside the open port or maybe it's a C-Ring groove. So I'll be hunting for the valve, spring, caps, retainers etc. I checked the IH parts diagram and most of the parts say superseded without any reference to what superseded them. It does have the single hydraulic pump. Thanks for your response.
