TractorLinks.com
Show Parts for Model:
Re: farmall 200
couv
04-13-2014 06:21:19
If yours has the Touch Control front hydraulic block under the gas tank, AND a separate cylinder for the hitch ,
then,
either the rear cylinder itself has worn packing and seals,
or
the valve on the right side of the Touch Control block is leaking internally
dewy
04-13-2014 06:26:24
 Re: farmall 200 in reply to couv, 04-13-2014 06:21:19
leaking internaly where it does have valve... wher back into resavor...how can i know for sure. dewy
Dean Olson
04-13-2014 11:47:51
 Re: farmall 200 in reply to dewy, 04-13-2014 06:26:24
Rebuild the auxiliary control valve on the side of the touch control. All fluid has to go through there to or from the reservoir.
There"s a block that both hydraulic lines go through. Located between the seat and shifter. It designed to slow down lowering the fast hitch so you don"t drop a heavy implement and damage it. Bypass that. I bypassed mine years ago thinking I"d fix it. Still on my to do list. As the fast hitch works so well I may never get it done.
In my limited experience with 3 super C"s and a 200 that will solve your problem.
So far any cylinder I"ve had leak down has leaked externally and was obvious that was the problem.
