Need a fuel metering stem
560farm
Location
NEIL
Looking for a metering stem #45139DAX for an H carb #6212DB. Mine was in two pieces when I pulled it out of the ultrasonic cleaner. Anybody got one? Thank you.
Brad
Brad, Looking up carb for H on CASE/IH PARTS. 45139DAX appears to be for all fuel carb and of course NLA. 56610DX STEM for gasoline carb shows still available from Dealer in $32 price range. The 56610DX fits 50981D or 50981DA Carb. This is IH D10 updraft Carb.
Bill
I had trouble at first tracing your 6212DB carb but just found it does sub from 45108 which is listed in catalog which is distillate or kerosene carb. So if that is what you have I am also striking out so far on finding 45139DAX. Still looking, however.
Bill
Thanks Bill. I new about the NLA but didn't check on the other stem part # for the 50xxx carb. That's interesting about having a dist/kero carb. I might have to check out the stem on our original "50 H to see what kind of difference there is between the two stems.
Brad
Brad, Someone gave me this link. www.mcdonaldcarb.com
McDonalds Carburetor and Ignition
706-367-4179
When you bring up the site and enter your # 45139DAX,it comes up that they have for $19.99
They also indicate that the #56610DX for the gasoline carb will work ?
Your are fortunate if you have another H and carb you can compare.
So maybe we are getting somewhere ? The Case/IH on line catalog does not show that they interchange ?
Good luck, Bill
